For some time now the update has failed. It downloads the files ok but gets about 70 pc into the install when it fails. I tied re=installing the program but that didn't help. So I tried un-installing and re-installing. But the program wont un-install. It fails with the following message: Service AVGIDSAgent could not be deleted. Verify that you have sufficant privileges to remove system services.
Help!
Thanks for the reply. I sucessfully un-installed avg with the remover.I also deleted folder avg which had a few files in it. I've tried three times to re-install the program but it keeps failing with the code: 0xc0070643
Hello Andrew,
Sorry for the inconvenience caused. I request you to try removing AVG using remover tool( http://aa-download.avg.com/filedir/util/AVG_Remover.exe ). Please restart to complete the uninstalling process. After restarting, Please go to the drive where you installed the remover tool and look for a folder named as "AVG Remover" and I request you to delete it manually. And then proceed with the re-installation of your AVG program and let us know the status. Thank you.
Hello Andrew,
Hello Andrew.
Thank you for trying it out and we appreciate your efforts so far. We have sent you an email instruction to get connected with our technical support team. Please follow those instructions to get in touch with them and you should be able to resolve your issue. Thank you.
