Hello Drew,
We regret the inconvenience caused. Please provide us with more information as when do the error occur and a screenshot of your error message which will help us to assist you in a better way. You can refer the following article ( http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot ) to take a screenshot.
We look forward to hear from you soon. Thank you.
Had all of the programmes reinstalled using AVG Express Installation order number 704-0397271. Problem is still there. Further to my other question .How come Technical Utilities found 644 issues when they did a scan as a solution for error 0 x 8007007A ?
Drew, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hello Drew,
