as i can see, my AVG internet security doesn't work. there is a title "NO ACTIVE COMPONENTS" and all circles are red. heelp!
Hello Andrew,
We are sorry to hear that you are facing issues with Inactive components. This issue occurs, when the AVG program conflicts with the latest update and the fix is to remove the traces completely using AVG remover tool and install the latest version.
Please click on the below link to run AVG remover tool :
http://files-download.avg.com/util/tools/AVG_Remover.exe to completely uninstall your AVG program from your PC. Once the AVG Remover Tool has done with its process. Please go to the C drive and look for a folder named as "AVG Remover" and I request you to delete it manually.
Once you are done with the remover tool please try installing the AVG program by clicking the following link: http://files-download.avg.com/inst/mp/AVG_Internet_Security_1930.exe
Feel free to contact us if you face any difficulties.
Hello Andrew,
