Hello Tom,
We apologize for the trouble caused. We'll check and help you.
Kindly share the screenshot of the pop up message you're getting using the below article, so that we can check and assist you accordingly.
https://support.avg.com/SupportArticleView?urlname=avg-create-screenshot
Awaiting your response.
Just a quick suggestion / tip. The large "here's how it works" pop-up over the On/Off button is very annoying. We all know how a VPN works or we would not be paying for one via a subscription!
Just to advise - and perhaps it helps - I do not see that issue on my Windows 10.
Agreed sounds like a Windows 11 / AVG relationship somewhere ![]()
Hello Tom,
Annoying pop-up that blocks On/Off button!
I have already done that a few times. It's simply an oversight by the software developers. Please let them know. If it helps, the pop-up ONLY happens on desktop program and NOT on the mobile App.
Thank you for sharing the screenshots, Tom.
Again, we're sorry for the inconvenience this has caused you.
Could you let us know whether the "Here's how it works" window is being displayed constantly or only when you move the cursor over AVG Secure VPN User Interface?
Appreciate your efforts in notifying this to us, Tom.
We'll forward this to our senior level support to notify the developers.
Please wait for a reply from them. Thank you in advance!
