Hello Quentin,
We understand that you wish to know how many devices are being used under your AVG subscription.
We request you to follow the steps below:
1)Open AVG app.
2)Go to Menu> My subscriptions.
3)You will be able to see the number of device your subscription is being used.
How can I find out how many devices I have used on my AVG multi device package?
To find out how many devices you have used on your AVG Multi-Device package, you typically need to log in to your AVG account. Here are general steps you can follow:
Visit the AVG Website:
- Go to the official AVG website and locate the login option. You may find it in the top right corner or in the website's main menu.
Log In:
- Log in to your AVG account using the credentials you used when you initially set up your AVG Multi-Device package.
Access Account Details:
- Once logged in, navigate to your account details or dashboard. This may be labeled as "Account," "My Account," or similar.
View Subscription Information:
- Look for information related to your subscription or product details. There should be a section that displays how many devices are currently associated with your Multi-Device package.
Contact Support (if needed):
- If you cannot find the information you need in your account dashboard, consider reaching out to AVG customer support. They can provide specific details about your subscription and the number of devices associated with it.
Remember that the exact steps might vary based on updates or changes to the AVG website or user interface. If you have trouble finding this information, refer to the AVG support documentation or contact their customer support for assistance. They should be able to guide you through the process and provide accurate details about your Multi-Device subscription.
