How do I clear out my clipboard once I've installed Antivirus Pro? Also should I delete the free AVG Antivirus?
Hello Jessica,
Clipboard Cleaner feature is available on the main screen of the AVG Antivirus Pro.
May I know if you see two AVG icons on your android phone? If yes, then you can uninstall the AVG Antivirus Free (which is asking for upgrade).
Regards,
Hello Jessica,
Regards,
