AVG Antivirus not working - Get your troubleshooting here
Anti-Virus Guard is commonly known as AVG Antivirus, designed and developed by Avast Technologies. Protects your computer from malware, spyware, and other harmful viruses. AVG Antivirus is compatible with Windows, macOS, and Android operating systems. AVG Antivirus has multiple benefits, but despite the fact that it also runs into a problem AVG Antivirus not working. Some of the few problems are mentioned below.
- If you get an "Installation Failed" error message, don't worry, you can install the same by following the simple steps.
- AVG Antivirus has provided various tools and to solve this problem please download the AVG Reset, Access Tool.
- After download, close all your programs and then run the downloaded file, and during this process, a dialog box will appear and it is about the license agreement, click "Accept" to confirm.
- In the next step, click "Continue" and then your computer will restart.
- After restarting the computer, you will be free from your problem.
