How to Resolve System Slowdowns After Installing AVG
Hello Alex,
We are really sorry to know that you are facing performance issue after installing AVG. We'll certainly check and help you out.
Performance recording allows you to easily report an issue if you think that AVG AntiVirus is affecting the performance of your PC. When you run performance recording, AVG AntiVirus for Windows captures technical data relating to your system performance. After you submit the recording, we can analyze the captured data to verify if AVG AntiVirus for Windows is causing your issue.
Refer the below article to check and use Performance recording option in AVG AntiVirus/Internet Security:
Performance recording in AVG AntiVirus - FAQs (https://support.avg.com/SupportArticleView?l=en&urlName=avg-antivirus-performance-recording-faq&q=performance+&supportType=home#idt_040)
If you are using another operating system, could you please more information to check this for you.
May I know your device OS name and version?
Could you please confirm which AVG applications you have installed?
Did you try after disabling AVG applications?
Are you facing issue only when you are using internet or overall system performance is reduced?
If you have more queries/questions, please write back to us
After installing AVG 2024, I've noticed a significant slowdown in both my system's performance and browser efficiency. For example, tasks that typically take seconds, like downloading my fesco bill, are now taking considerably longer. Could you advise on the required adjustments or settings that could help restore speed while maintaining security?
Hello Alex,
