How to speed up VPN
It is night and day with VPN on, example I did internet test around 150 mbps without, 50 mbps with VPN, with VPN takes around 5-8 seconds to load anything, I'm thinking of cancelling and finding a faster VPN
Hi Kevin,
We're glad to clarify this for you.
You may sometimes experience a slower internet connection when using AVG Secure VPN.
This is because VPN encrypts traffic and data before sending it to a server.
Depending on the distance and capacity of the server, this process may cause a slightly slower, but safer, internet connection.
However, you can try connecting to different servers (location) in Secure VPN to identify the server that provides better connectivity.
Hi Kevin,
