Hello Ghisele,
May I know the exact error message that you receive when you try to remove AVG components?
We request you to try using AVG remover tool once.
1) To download AVG remover tool, please click on this link: http://aa-download.avg.com/filedir/util/AVG_Remover.exe
NOTE: Once you have logged into your PC after the restart, please go to C: drive and delete the "AVG REMOVER" folder manually.
Hello Ghisele,
Want to get rid of all AVG components but am having a hard time doing so.mCan anyone please help me with some widget error message, please?
