I need help (spanish/english)
Hello Nancy.
Support is currently available in English only. Please use a translator (for example, http://translate.google.com/) to read our reply.
We'd be glad to help.
Do you mean AVG is forcibly detecting a 3rd party program update as virus?
Could you share a screenshot?
Mi antivirus detector un malware , pero la aplicacion quien la tiene es "Actualizacion" dice que no la puedo desitalar pero si desactivar me dirigi a la app y dice " forzar detention"¿Que hago? / My antivirus detects a malware, but the application who has it is "Update" says that I cannot disable it but if I deactivate it I went to the app and it says "force detention" What I do?
Hello Nancy.
