Hello Mohinder,
We request you to try the repair installation of AVG Internet security once.
To perform repair installation please follow the instructions mentioned in this link: http://avgread.me/1BVxDSY
I have installed AVG Internet Security product in my dell PC. It shows Identy not protected. Problem not also solved on Fixing. Kindly give advice…
Hello Mohinder,
Dear Balasubramanian, experiencied a problem during repair installation of AVG internet security. Description : Invalid parameter specified. Error code : 0xE0010002. Kindly assist to solve the problem. Thanks.
You are welcome.
Thank you for trying the repair installation.
Sorry to know that it ends up with the error.
In this case, we request you to try reinstalling using the AVG remover tool.
1) To download AVG remover tool, please click on this link: http://aa-download.avg.com/filedir/util/AVG_Remover.exe
NOTE: Once you have logged into your PC after the restart, please go to C:\ drive and delete the "AVG REMOVER" folder manually.
To download, install and activate AVG Internet Security please follow the instructions mentioned in this link: http://avgread.me/1DXPL5z
