Thank you for your valuable feedback, Shane.
We appreciate your efforts in trying to provide a workaround solution.
The micro-update/fix will be released in the next 24 hours.
Till then, your patience is appreciated.
Further to my already reported issues regarding Microsoft Office and PDF issues since the June 10 update, in addition, AVG Tuneup forces Microsoft Clicktorun into ‘Disable mode (meaning no Office products will open at all until this has been switched back to Automatic or Manual mode) Even after forcing this back to Automatic mode, after a certain period of time, or after each time AVG Tuneup runs it forces it back to disable.
Can you please attend to this function also as each time AVG Tuneup updates I have to select this back again.
For those wishing to check type ‘services.msc’ in the ‘type here to search’ in your taskbar. Once the list populates, scroll down to Microsoft OfficeClickToRun and check to make sure under ‘Startup type’ that it is set to Automatic or Manual.
If it isnt then right click on Microsoftclicktorun , select ‘properties’ and change Startup type to Automatic or Manual.
This service is required to run during the use of any Microsoft Office program, during initial streaming installation and all subsequent updates.
Also, can you please advise what tome frame you suspect you will have a fix prepared for Office prodcucts and PDF functions as many people are relying on this to conduct normal business operations.
