Input code in Android for AVG-zen
Hello Balasubramanian,
Thank you and Alan Binch for your answers in detail. However: in one of the latest steps, as indicated, I had to give my parameters in the free-version. After filling in in 'my account' my e-mailadress and password as registered by AVG in that android, I didn't find the connection in my home page of AVG, even after 24 hours. It is still on 'demand'. My own android, as wel as another PC is present well on this page. I suggest my partner is still working with the free-app.
m.vr.gr. Paul Klück
Paul, Have a look @ this link (https://support.avg.com/answers?id=906b0000000E2YXAA0).
I want to enter a code to connect an Android mobile to my AVG -zen license. However I cannot find the desired button in the list above at the left side. Where can I find it.
Paul, Please note that AVG Android support is provided through email only.
m.vr.gr. Paul Klück
Please download AVG Antivirus and AVG Cleaner from Google PlayStore on Android device, install it and then enter AVG my account by following below steps:
1.Device Menu -> Settings -> Apps/Application Manager -> AVG -> Uninstall.
2. Restart your device once.
3. Open Google play store app on your device.
4. Search for AVG antivirus/cleaner.
5. Locate and install the free version of the app.
6. Now open the installed app.
7. Tap on drawer (3 lines) on top-left of the app.
8. Select AVG Account.
9. Enter your My Account email address and password.
The paid app should get installed automatically.
Hello Paul,
Please be informed that "ZEN" application is no longer available for AVG apps in Android.
Hence it is not possible to find the option for entering invitation code.
We are working to implement a best design for Zen interface but this process will take time.
However you can still activate the paid subscription in Android by entering the AVG my account credentials in the app.
If you purchased the AVG Unlimited devices product through Google PlayStore then you can activate it using my account credentials.
