Inserting images in a problem report
I performed an AVG uninstall and then an avgclear. after a re-install of AVG free, it appears to  be functioning properly now. BTW locating the menu option to perform a weekly scan was very difficult to find. Had to click the 3 dots to the right of the run smart scan button to get to it.
Hi Best,
We will help you in this.
Why and which image are you trying to insert in a bug report?
Could you share us the screenshot of the that image as well as the 'Only accept a URL' message?
Refer this article for the steps to capture the screenshot : https://bit.ly/2Y6RCDP
If you try to insert a desktop snapshot in a bug report, you get a pop up window that will ONLY accept a URL beginning with http: How/when will you EVER have a desktop snapshot that has an http: address?!?!?!?
Thank you for updating the status, Bert.
Glad to know that your issue has been resolved.
Regarding your concern about the weekly scan, we're sorry for the inconvenience caused.
For more information about running different types of scans in your AVG Antivirus Free, please refer to this article.
If you have further queries, please write back to us.
the problem I'm reporting is I am not allowed to insert an image in a report, so there is no way for me to provide a snapshot that you are asking for. I'm trying to report several issues but without the option to insert a snapshot. I can't provide a visual image for you to see of either issue. your website support tea needs to look at and fix this image insertion problem before I can show you the problem. BTW I know how to create a desktop snapshot.
We apologize for the inconvenience, Bert.
We've sent you an email. Please attach the screenshot(s) of the message(s) you're referring to, as a reply to that email.
So that we can check and assist you further. Thank you for understanding.
Hi Best,
