Install Problem for Ultimate
Hello Ian,
We regret the inconvenience caused. Upon checking with your account we can see that you have been registered with AVG Ultimate.We would request you  to remove previously installed program traces of (AVG 2015 or AVG 2014)from your system using AVG Remover tool and then try to reinstall AVG Internet Ultimate.
Note: If you have installed any other conflicting programs like AVAST, NORTON, McAfee or KASPERSKY  try to uninstall it.
Once you have uninstalled from your system,try to follow the steps which mentioned below.
Remover and Download:
1) To download AVG remover tool, please click on this link:  http://support.avg.com/SupportArticleView?urlname=How-to-reinstall-AVG
I have a number of laptops, PC, Mobile all installed fine. This Laptop No NO...have checked for other AV's running and not, still getting install failing after download.
Windows 10 6G Ram Core i3 Processor Toshiba Sat. Pro.
Any help would be good help.
Hello Ian,
