Hi, Robert.
We're here to help. Could you confirm from which website did you download the AVG PC TuneUp setup file and operating system that you are running?
That's okay, Robert.
Merging all your products into AVG Ultimate costs nothing. We need to escalate this case to our senior team to perform this process.
Please follow the instruction ( http://support.avg.com/SupportArticleView?urlname=How-to-troubleshoot-issues-after-upgrade-to-the-latest-AVG-antivirus-product ) to run AVG Clear tool & remover tool to uninstall old traces of AVG.
Download AVG Internet Security Unlimited & Tuneup Unlimited from our official website: https://www.avg.com/en-us/download .
I renew subscription. Have Key. Tried to install message states "this version of PC Tuneup will not run on this PC". First time I've had this happen, and as far as I know it is the same product originally purchased and installed for this Surface Pro.
Robert, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hello Robert,
Let's work together to fix it. Please share the screenshot http://support.avg.com/SupportArticleView?urlname=Create-screenshot of that error message to check and assist you further.
I see that you have same products twice with different activation methods. You have AVG PC TuneUp & AVG TuneUp - Unlimited, AVG Internet Security - Unlimited and 2 AVG Anti-Virus. Shall we merge all your products into AVG Ultimate which include both features in a single package?
How do I insert a screen shot of the message? It just simply says "this app can't run on your PC. To find a version for your PC, check with the software publisher. It only shows up when I attempt to upoad the sofware I paid the renewal for. As far as products, I don't want to add cost to my subscription, so if AVG unlimited cost less I'm ok with that, if I don't need all the various apps then I will cancel my subscription to those I don't need as you've mentioned.
Hi, Robert.
I purchased the renewal via the AVG notice I received about my subscription expiring from avg.cs@digitalriver.com. (http://store.digitalriver.com/store)
My operating system is Windows 10 Pro vs 1803
