Hello Ferry,
I'm sorry to hear about this, I have sent you an email, please follow the email instruction to connect with us remotely. We will check with your computer/error message and we will help you to install AVG Ultimate program.
Best regards,
Dear All,
I got problem when I am running installation.
"C:\Program Files (x86)\AVG\Framework\Common\avguix.exe
The application has failed to start because its side-by-side configuration is incorrect. Please set the application even log or use the command-line sxstrace.exe tool for more detail.
How to solve this problem?
Hello Joe,
I'm sorry to hear about this, please let us know if you want to install AVG PC Tuneup trial or AVG PC TUneup paid version and also provide the screenshot of the error message to assist you further. You can check the following link to see the instructions about taking the screenshot (http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot).
Best regards,
We are having the SAME error on installation of AVG PC TuneUp. Please advise.
Hello Ferry,
Best regards,
Joe, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
