Thanks Alan,
Yes I also see error code 0xC007001C
Ive just tried all the methodes mentioned in this acticle but I still get the same error(s).<br>Theres one thing…There are two windows updates which my computer fails to install, KB2830477 and KB2592687, althought Windows defines them as "optional" do you think it has something to do with the AVG inst. error? If yes, please advise and if not, well…please advise ![]()
Thanks Alan,
Joe, In order to analyze it please provide AVG with diagnostic output using this tool (http://download.avg.com/filedir/util/AVG_SysInfo.exe) and please add detailed description of issue.
Last week Ive purchased AVG Internet Security 2015 after using the 2013 version for 2 years.<br>When I try to install it I get "Driver installation failed, Error code 0xC0070643"<br>The actions ive already took:
- Uninstalled AVG 2013
- Used AVG removal tools (several times)
- Deleted all the malware programs I had on my pc
Nothing works, please help!
Joe, Are you seeing any other error code as well i.e. 0xC007001C. If so, Have a look @ article (https://support.avg.com/SupportArticleView?urlname=Code-0xC0070643-or-0xC007001C-when-installing-AVG).
