None of the instructions I received worked. So I reset my computer - and now AVG works fine. However, I have a lot of work to do to set up all my favourite applications.
Gavin
I have just bought AVG Ultimate and found that when I download AVG Myaccount and try to install it, the installation fails and I am told to uninstall the old version.
But according to my Control panel, I have no existing installation of AVG. And then when I try again I get the same failure to install, and the same warning.
Can you tell me what to do please?
Thanks, Gavin Atkin
Hi Gavin,
We apologize for the inconvenience caused to you and T assist you better please provide the screenshot of the error message.
Gavin
Hi Gavin,
Hello Gavin,
You can find answer to your question together with your another post here.
https://support.avg.com/answers?id=906b0000000De0S
Please try keep whole conversation in one question/thread to speed up resolution.
