Installation Problem
Alan, I uninstalled AVG 2013 with the uninstall tool. When I downloaded the AVG Protection and ran the file it would not install. It says the file is corrupt. I tried restarting the computer, using CCleaner for registry files, and opened an official file with AVG techs. They couldn't fix the problem. It is now being reviewed by more techs.
James, Which AVG product install file are you actually attempting to download?.
Hello James. I apologize for the inconvenience caused. While verifying your records it seems that our senior level technicians are working on your issues and will get back to you as soon as possible and the resolve the issue for you. Thank you.
When I download the file, it says, "File is Corrupt" and will NOT let me install it. Why?
