Installation problem
Hi Alok
I have followed the Sophos instructions for the removal of their antivirus and also run their removal tool which failed. Now when I try to install AVG it says it is verifying but nothing happens.
User-added image
Hello Tony,
Share the screenshot of message that says "Sophos antivirus security software is already installed" to assist further.
Thank you in advance.
I am trying to install AVG Antivirus on a Mac to replace Sophos antivirus. On installation I get a message  "Sophos antivirus security software is already installed on your machine. AVG AntiVirus cannot be installed as it may not be compatible with your Sophos antivirus security software."
I have moved all Sophos files from the Applications and Library folders to trash and emptied trash and rebooted but I still get the same message.
Help please.
I have already been in touch with Sophos support about this issue and they were no help. I guess all I can do is try them again.
Hi Alok
User-added image
Hello Tony,
Tony,
We appreciate your efforts in trying to fix the issue. Try it again and check if it helps.
Tony,
Thank you for your patience. I request you to follow Sophos guide for removal of their Antivirus https://goo.gl/D8586r at first, reboot your computer once and try again to install AVG Antivirus.
Best regards,
Thank you for the screenshot.
I have forwarded the case to senior team for getting suggestions.
Keep checking this post to know about the status.
Your patience is much appreciated.
