Installation problem
Dear AVG,
I'm having problems with my AVG installation on windows 7 I have tried it many times
by this error  code "0xe001f98d" keeps on appearing.I also tried using the AVG remover buy it's not working. I also uninstalled it on my programs. Please help me.
Jojo,
We are sorry to hear about the inconvenience caused. We appreciate all your efforts in trying to fix the issue. We request you to restart your device, use our AVG remover once again as suggested here: http://avgclick.me/UninstallAVGAV.
Then please remove AVG folders manually as suggested below. Go to Run window (press windows key and R key simultaneously) and type the following comments to delete the folders.
1. Type  “Temp” and press enter, remove all the files.
2.  “%temp%” and remove all the files.
3.  %appdata% - Remove all the AVG folders.
4.  %programdata% - Open the AVG folder and remove the old files.
Please go to c: drive-> program files and delete the AVG files and download your AVG program from our official site: http://www.avg.com/us-en/download.
Please, feel free to let us know if you require any further assistance. Thank you.
