Installation problems
Hello Christelle,
We request you to completely reinstall the AVG program using our AVG remover tool.
1) To download the AVG remover tool please click on this link: http://aa-download.avg.com/filedir/util/AVG_Remover.exe
3) Your computer will be restarted automatically. After the restart, AVG Remover will finish the uninstallation.
Upon checking your record, we see that you have purchased our AVG protection multidevice subscription, To download, install and activate it, please follow the instructions mentioned in the following article: http://avgread.me/1FKGRZI .
Hello Christelle,
Hi
I keep getting  Error code: 0xC0070643 Event exec_finished. Please let me know what I should do since I've been spending the past 2 hours trying to figure this out!!!
thanks
