Hi Lei,
We apologize for the inconvenience caused.This isn't the experience we want you to have.
Kindly explain the issues you are facing after installing the AVG in detail to help you in this.
After installing the AVG Ultimatethe following issues I'm facing: excuse for my Englosh I do my best.
The system performance slow down very bad,
Different function are not working
System incompatibility
Diverend Apps don't work
further I got 2 licence numbers the one for Virus Removal Assurance is not accept.
Hopfully you can help.
Kind regards,
What you want me to do with the link URL?
After instalation AVG Ultimate i have a lot off problems, mine PC does'nt work correct anymore
Kind regards,
Hi Lei,
Thank you for the explanation.
Please accept our apologies for the inconvenience caused.
Did you optimize the computer using the AVG TuneUp?
Could you mention the optimization level in the program?
How do you suspect that the AVG is blocking the other programs?
Did you get any error message?
Virus Removal assurance is the premium subscription to contact our remote support. They will assure that the computer is Virus free.
Keep us posted.
I already send a answer, but I can trust my PC
After installing the AVG Ultimate following issues I'm facing: excuse for my English I do My best.
The system performance slow down very bad, Different function are not working
System incompatibility, Diverend Apps don't work
Hopefully you can help.
Kind regards, What do I do with the URL link
Kind regards,
Kind regards,
