Installation window does not open
Hello Imam,
Yes, we will surely help you in resolving this issue.
We request you to press Windows and R keys together on your keyboard which will open the "RUN" command window.
On the RUN window, please type as "services.msc" without the quotes and press Enter key.
This will open another window with the services list running on your PC.
On the list please scroll down to select "windows installer". Please right click on it and select "Start"
Once done with this please run the installation file and let us know the status of it.
Hi
I have a problem with installing AVG on my PC. I downloaded the file which is around 3.3 MB but when i click on that to launch it does not open. Can you please help me as to how i can fix this and install the product i purchased.
Hello Imam,
