Hello Norbert,
We are sorry to know that the installation fails. To assist you better, could you please send us the screenshot(http://avgclick.me/getscreenshot) of the AVG error message you receive? And also, please make sure there is no other security software is installed in your computer.
Thank you
I've got a windows 10 system. The exact error message is Description: Event exec_finished. The installation runs to about 96%. Have tried the AVG_Remover_en and AVG_BFEfix to no avail. The removal tool fails to run. Rebooted numerous times during attempting to install and remove to no avail. I've tride the AVG remover 2015 as well but I've got the same message.
Norbert, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hello Norbert,
Thank you
