To download, install and activate AVG Protection, please follow the instructions mentioned in this link: http://avgread.me/1FKGRZI .
Please note that you have only purchased AVG protection subscription so on the Zen interface you can find performance circle also and on this you will get only the trial version of AVG PC tuneup installed, if you aren't interested to use this then please uninstall only AVG performance from the control panel.
Hello Craig,
Please make sure that you have logged in as a admin to your Zen network.
If you have logged in as admin but still getting trial installed then please use remover tool and install AVG protection.
1) To download the AVG remover tool please click on this link:
I have purchased avg protection pro and tried ti install it to a second lap top ,but it loaded the free trial period version, how do I load the full version on a second lap top? Thanks
Hello Craig,
