Installing Problem
Hello Rafael,
If this error appears, it is necessary to run AVG remover tool and click on "Run Anyway" to proceed with the removal.
Once it is completed, try installation and inform the status.
I tried to install AVG PC TuneUp and at the end of the installation it presents the following error code:
0xa001f90d.
I ran the AVG Trace Remover tool and nothing was found. I use Windows 8.1
When I said that I ran AVG trace remove, I was referring to the AVG remove tool. I had done these operations before, and it did not help. The same error keeps popping up.
Rafael, appreciate your efforts, but I regret to hear that the issue persists. I have sent you an email with instructions to get connected with our remote assistance team. Please follow those instructions to get in touch with them to resolve your issue.
Hello Rafael,
