Internet connection problems because of the fire wall
Around 9pm last night. i was on google AVG was updateing. when i closed the web page. and went to reopen. would not open. computer shows i have connection. tried to start up a uoline game error time out on connection. tried several ways to connect. got intouch with my internet provider. we talk are way around the system and came to fire wall. AVG Fire wall was set to auto. changed it to ask before blocking. no change. third setting was block internet, nope dont want to do that. last setting is disable fire wall… WOW … i have internet. so i went back and test the different setting again. found out that your fire wall setting are not working properly  in auto, and the ask before blocking setting is not working. Is there a way i can go into the setting and changed these setting or should i just reset to default setting?
Hello Stephen. I request you to uninstall and reinstall your AVG Ultimate to fix the issue that you face. Thank you.
