Issue With Quarentine Options!
I've been using avg for over 10 years. This most recent avg basic I understand has less options than ever before which I can understand since they have to make money too. BUT the fact that you cannot check out where the path leads in the quarantine folder really upsets me. I should be able to find out where this threat originally came from and it wont allow me to expand the window nor move the collum over to see where  the path ends so I may know not only what file is taken away but where it originated so I can prevent another problem. I really hope they fix this in the next update. I'm at the point now where i'm ready to stop using this program after using this since Windows Xp!
Steven, Did you resolve your issue with AVG?. If not, Just keep checking for any new updates which might appear.
