Java script does not work with AVG
Notice says java script will not work
Hi George,
Would you be so kind as to elaborate the exact issue & share us more details?
Please specify the name of the AVG program that is not compatible with Java script.
Did you receive any message stating that Java script doesn't work with AVG?
If you did, please share us it's screenshot, so that we can check & help you accordingly.
Thanks in advance!
Hi George,
Thanks in advance!
