Hello, Stefan
We will check and help you.
Could you share the screenshot warning message you receive from AVG?
Sometimes, when I Start my computer, which taxes approximately 1 minute to find the right wifi, AVG comes with several warnings Kitty wear?
What does this mean?
Yours regardely, Stefan Gulyuas
We apologize for the inconvenience, Stefan.
We need the screenshot of the warnings you keep receiving, so that we can discern the exact nature of them and to check and assist you accordingly.
Refer to this article to take a screenshot.
Thanks in advance.
Hello, Stefan
Thank you, Rakshith for your answer! What you propose I don't understand. Because I am not so good with computers…
Perhaps it helps if I explain more about what happens…
Sometimes, not always, when I start up the computer. Pop-ups from AVG appear which says: Kitty leaks, internet is not availabel. Then after a few seconds this pop-up dissapears, and with a delay I finally can go on the internet. Sometimes there is only 1 pop-up, but usually 2.
Yours sincerely, Stefan Gulyas.
