Hi I just bought a licence key for AVG driver update but everytime i copy the key into the licence box and hit activate it tells me that there was a problem and i either have to check the serial number or make sure i'm connected to the internet. Can anyone help me?
Hello, Christopher.
We request you to copy & paste the registration key to avoid typographic errors. Also, make sure that your internet connection is working fine. If you have Malwarebytes installed on your PC, disable it and try to activate AVG Driver Updater.
