Linkscanner Database problem
Hello Jackie,
Please accept our sincere and unreserved apology for any inconvenience this may have caused you. Please be informed that our technician are working with high priority to resolve the issue as soon as possible.
Jackie what did your friend do differently to what AVG keep suggesting to people?
I had this problem also … but the universe just happened to send my way a friend for a random visit, and the  problem is now fixed.  my friends doing your job for you.  thank your AVG support for all the help that you didnt give.  I'm now questioning whether I will continue with your product?  This is/was your problem to fix … not your client base!!!
Cheers J
We agree with you, Jackie.
The issue is fixed now and you should not have any issues further.
Hello Jackie,
@ Aravindh (AVG Technologies)
Aravindh, If you read Bruce Jamieson's posting again you'll see that their problem was solved.
yes but my issue is >>> this was a glitch in AVG system and not the fault of AVG users >>> AVG should have been fixing it on their end, not getting AVG users to fix it.  What would have been refreshing was >>> to see something from AVG letting their client base know that there was an issue with this update and that the technical crew were onto it.  Not a same size fits all remedy "follow this link" for everybody that was popping up with the Linkscanner problem. When all is send and done it is the public paying for this product.  A public apology from the company would have also been refreshing.  But hey this is the way of the world now isnt it!  Maybe food for thought >>> if there is a technical problem within the company, some sort of update to let the client base know this!  Instead of leaving the client base in a parallel universe wondering if it is just them.  Cheers J
Hello Bruce,
We really appreciate your valuable efforts which you have taken to fix it. Feel free to contact us for further assistance. Thank you.
