Long scans for "performance Issues"
Hello Nikolaj,
We are here to help.
Please repair your AVG program once and verify the status. To do so, refer the below steps:
- On the Start menu enter Control Panel in the search box and select Control Panel from the results.
- Select Programs > Programs and Features, and then select AVG Internet Security.
- Select  'Uninstall' and you will be getting an option to repair.
- Restart your PC to save the changes made.
Keep monitoring the status and inform us here.
Hi. Long scans for problems with proizvoditelnosti.
Hello.  Let them send you another letter when they are available. #08707664
Thank you for understanding.
User-added image
User-added image
Thank you for your prompt assistance.
