Mac upgrade to BigSur - AVG The problem is on our side
Hi Mike,
We're glad to help you with this.
From your description, it seems that few permissions needs to be provided to AVG program, in order to activate all the components.
To do so, follow the steps in this article & let us know if it helps.
Hello,
After updating my mac to BigSur AVG says my Mac is not protect for Computer or Hacker attacks.
When you click on either it claims File field is not enabled. Then says,'The problem is on our side"
Both items say the problem is on your side.
Why is this a problem? and how long to fix it?
Thanks,
Mike
It seems to be working now. Thanks. All green.
Hi Mike,
