Maintenance fix and clean issue
I ran maintenance on AVG tuneup and it says 1,108 issues found, 164.6 MB to clean up. I am not able to click "fix & clean" button. It is a dull turquoise color instead of brighter turquoise. Please help.
Thanks!
Hello Andrea,
We will check this for you.
Just to make sure you are using the latest version of the AVG TuneUp or not, does the application says AVG TuneUp or AVG PC TuneUp?
Can you share us the screenshot of the disabled 'fix & clean' button?
Refer this article for the steps to capture the screenshot :
https://support.avg.com/SupportArticleView?urlname=AVG-Create-screenshot
Hello Andrea,
