Hi Claude,
We will help you to resolve this issue.
Having Malware Bytes and AVG Antivirus on the same PC will conflict each other. We request you to uninstall Malware Bytes from control panel and run AVG Antivirus alone on your PC.
Also share us the screenshot of the AVG Internet Security/Antivirus user interface to check and assist you further.
MY Avg has stopped updating it staes it's up to date but i can see red flags stating the link scanner and Anti -virus and spyware are out dated…i have the full malware bytes plus hitman pro installed
Hi Claude,
Thank you for providing us the screenshots.
It seems like you are still working on the old version of AVG Internet Security program.
We suggest to use our AVG clear and remover tool by referring to this article to remove the old version of AVG Internet Security and its traces, then reinstall the latest version of AVG Internet Security application by following the instructions given in this article and check with the issue.
And we also request you to remove Malware Bytes from your PC to avoid the conflict.
