MS Remote Desktop Connection
Hi Steve,
We are sorry to hear this.
Let us configure the Firewall and check for the issue again.
Refer this article and follow the steps mentioned https://support.avg.com/SupportArticleView?urlname=AVG-Antivirus-Enhanced-Firewall-System-Rules
Refer this article for configuring the Application rules https://support.avg.com/SupportArticleView?urlname=AVG-Antivirus-Enhanced-Firewall-Application-Rules
Hi
I have just bought AVG, and my MS Remote Desktop Connection won't connect anymore.
If I disable Hacker Attacks in the AVG Enhanced Firewall the Remote Access works fine.
But how can I change this to allow Remote Access and still block hackers?
Hi Steve,
