ita solved some time ago, during ilness not answered earlier
Hello Shankara
As in 3. of my first answer, I tested al the possibilities, VPN on and of with firewall on and of.
The first action I made after failing several imes to make connection and getting the error message above was re-installing AVG ultimate from myavg
kind regards Noud
Hello Noud,
We will check this for you.
Please share the screenshot http://avgclick.me/getscreenshot of the new network created on your computer.
Are you using AVG Secure VPN or a different VPN service?
If you suspect AVG protection is causing this issue, please disable AVG temporarily on your computer and check if that fix the issue.
To disable AVG temporarily, please right click on the AVG icon present at the bottom right corner of your desktop(System Tray) and use the slider to "Disable Protection".
Running win 10 1809
using a VPN service
Trying to connect to a MS wireless display adapter.
Did use the configurations as discribed in the community.
This used to work, but after the last upgrades of AVG and/or Windows nothing works
Every time I try to connect there seems to be a new network with a different name.
Does anyone have a sollution
Noud,
Thank you for the info.
We would like to determine the exact cause of the issue. We have sent you an email with the link to get connected with our technical team. Please follow that email and you will be able to resolve the issue.
Hello Shankara
kind regards Noud
Glad to know that, Noud. Thank you for updating the status. Hope you feel better soon. Have a great day. Stay safe!
Hello Noud,
Hi Noud,
Did you try connecting MS wireless display adapter by turning off the VPN and keeping the Firewall active?
I would also like to know if you have the latest 19.3 AVG version installed?
Hello Karthikeyan
New info: when I try to make a networdk connection (every network !!) a popup is shown saying the network profile is set to public, if I click change, a error message error message is shown. see screenshot
Kind regards
Hello Karthikeyan,
- In the attachment you'll find the screenshot
- I'm using NordVPN as my VPN-service
- I several times cand hecked if disabeling AVG-firewall made the connection possible. Each time I disabled yhe firewall (even with VPN-service live) I could connect through my MS wireless display adapter, the second I enabled the AVG-firewall again the connection stopped.
