Hi Michel,
We're glad to help you with the info.
The option to remotely manage licenses on your devices isn't available currently.
Also, we do not have the devices info apart from the number of devices in which your license is used.
We're afraid as we'll have to check each devices manually for the subscription status.
Thank you in advance!
Hi, I can see that my AVG subscription is used on 7 out of 10 devices. Can I see on which devices and can I remotely or remove it for a device?
Hi Michel,
