Hello Stephanie,
We regret for the inconvenience caused. While verifying your account you have AVG Protection as your active subscription. Please check whether you have installed any other conflicting applications like McAfee, Avast, Norton etc… on your PC, If so please uninstall the conflicting applications.
If not, please click this link http://aa-download.avg.com/filedir/util/AVG_Remover.exe to download and run the AVG Remover tool to remove all the traces of the AVG.
Hi I please want some help. My tablet broke I want to take off the avg from the tablet but dont know how i can do it the tablet is broken.
I cant download avg on my husband computer it gives me this message(please help)
Sorry an unknown issue has prevented internet security from installing. Please give it another try, and if the issue persists, contact our friendly support team and give them thiserror code: 0xc0070643 Descirption: Event exec_finished
Hello Stephanie,
