My AVG is showing I have A trojan horse PSW. When I clicked remove AVG says it is bigger than 5mb and can't be removed. Am I protected and how do I remove it?
Detection should tell you the filename and path. At that size, my guess is it's a freeware installer that you downloaded, in which case delete it manually.
Hi Paul,
Please try delete it manually as suggested by John.
