My device locked and need 4 digit pin
Hello Naresh,
I regret for the inconvenience caused. To best assist you with this, I suggest you to contact our AVG Mobile support. Please click on the following link ( http://avgclick.me/AVGtechnical ) and fill out your details, select as platform as "Android" and the name of AVG Program that you have installed in your mobile. In the description please completely explain about your issue and finally click on "Email" option. When filling out your details choose "Yes" for the question "Are you currently using any paid/trial AVG products?" even though you may be using the Free version. The AVG mobile team will reply to you via email with a resolution.
Hello Naresh,
Sir actually may Samsung device locked and need four digit pin number and I am not able to open without pin.tell me what is my pin and not show the location.
Naresh, Please note that AVG Android support is provided through email only.
