Hello Allan,
We are glad to clarify your request. Once the AVG Internet Security gets updated, the network profile will set to default one. Here, the the default profile is Public.
Also, in the latest version of AVG Internet Security, you can also change the profile from public to private. If you are not getting that option, we request you to share the screenshot (https://support.avg.com/SupportArticleView?urlname=AVG-Create-screenshot) of advanced protection page. So, we can check and help you with it.
I'm using AVG Internet Security (Multi-Device) and it did an update (I'm assuming within the last 24 hours or so) where I can see my networks are all set to public but nothing to set them back to private. Previously I used to go to the advanced protection section, go to the network settings and change the drop down from public to private whenever I connected to my vpn.
I've checked every screen possible and the only spot I found to change the network connection settings was in the notification window but after I had changed most of them to private the notification had vanished and I can't find the screen again.
The only way I appear to get teamviewer vpn working is to disable network protection from my laptop via my mobile to my home machine is to disable AVG on both ends which I have a feeling isn't a good idea.
We're glad to know that you've managed to find and resolve it.
For further queries or need assistance, feel free to reach us.
Have a great day!
I finally found how to access the settings. It moved from the settings section to the main screen. Web & Email -> Enhanced Firewall (open button) and the screen that shows has the list of networks where you can then go show settings -> I trust this network.
