Sorry, forgot to mention we are still running Outlook 2003 on a server with MS Exchange.
Hi Janet. I'm sorry to hear about the inconvenience caused to you. Please try disabling your AVG Antivirus Free and check if the issue persists. You can click on http://avgread.me/1GnMD3N to show the steps to disable your AVG. Please let us know the result. Thanks.
I have just uninstalled AVG Free from a work computer as it was running slow after scanning. I reinstalled AVG Free 2015 and now only the header of emails appear - no body text. Can anyone tell me what setting I have missed? I have compared settings with my computer which works fine and can't find any difference. Thanks
Janet, You shouldn't be using AVG Free on a work computer if financial gain is involved. It's actually only meant for home computer use. Anyway you could try disabling email certification to correct your issue.
