No Definition Updates In Two Days - Problem?
Hi
I'm also using AVG free antivirus and my last update was also on the 9th October (Virus Definition 19100902). Whenever I check for updates my virus definitions say 'Up to date'. Have there been no new updates in the last five days?
Hi
Hello Michael.
Thank you for reaching us here.
I'd like to inform that your AVG have the latest virus definitions installed from the version number you gave.
Please note that there is no specific time frame for the definitions to be released. AVG usually install streaming updates (smaller in size) daily. But this is not updated on the user interface. The status is updated only when a big update is released and installed.
I use AVG free antivirus which seems to be ok, but on all my machines the virus definitions have not automatically updated to more recent versions. My AVG says last updated 9th October at 09.06 hours version 191009.2. I press check for updates but I am told I am up to date.
I do not want to try the repair option until I receive a response from you.
Thanks Sarath. Appreciate it.
My pleasure, Alastair.
If you have any queries with AVG, you can create a new post for further assistance.
Hi Alastair,
The AVG virus definition version you provided is the latest update from us.
I would like to inform you that there is no specific time frame for the definitions to be released.
Hello Michael.
