No permission problem
Hello David,
Thank you for contacting AVG support community.
I apologize for the trouble caused.
Could you please confirm if you get any error message?
We will certainly help you out.
Thank you for writing us back, David.
We apologize for the inconvenience caused to you.
We certainly check and help you with the issue caused
We have sent an email to your email address offering additional help please check the email and revert us back for further help.
Hi John,
Thank you for sharing a workaround solution.
If you need any assistance with AVG, please write back to us in your own/new post, so that we can locate your account, obtain further details and help you accordingly.
Thank you for understanding in advance!
Thank you for your efforts, David.
Now that we identified which AVG program is causing the issue, we'll check which component in AVG Internet Security is causing this exactly.
Please Open AVG Internet Security > Web & Email > Turn off the web shield component and access the site then check the issue.
If it works, then kindly use the below article to repair the program, reboot the PC and check if the issue persists.
> (https://support.avg.com/SupportArticleView?l=en&urlName=repair-avg-antivirus&q=Repairing+AVG&supportType=home)
After repairing AVG I still cannot get on the post office web site, unless AVG VPN is shut off.
just for your information.
thank you
After installing an AVG package, VPN and AntiTrack, the US postal service will not let me access their website, stating I have no permission, and give this lengthy reference number:
Reference:13657493585243224224666998579627331348320034968299102359
Hello David,
May I know whether you have disabled AVG Internet Security and checked the issue? If haven't please do so using the following steps:
  • Right-click the AVG icon in the notification area of your Windows taskbar, then in the menu that appears, click the green slider next to Protection is ON.
  • Click OK, stop to confirm that you want to disable all AVG protection.
  • The slider turns red (OFF), and all AVG components are disabled. AVG protection will re-enable automatically the next time you reboot your PC
thank you
this is the full message from the USPS
You do not have permission to access this page If you have found this page in error, please contact support Reference:145840922211575143771105754448961007137820034968299102359
Hi John,
