Not able to connect
Hello Tom,
You've reached the AVG community support forum.
We regret the inconvenience this has caused you.
Our team is already aware of the issue and they have fixed the technical issue. You can connect to VPN again. But if the issue persists. Please follow the below instructions:
1. Open AVG Secure VPN and go to Menu and choose Settings.
2. Select "VPN Protocols".
3. Then select Mimic or OpenVPN protocols.
4. After changing the protocol to mimic, try enabling the VPN to connect with the server.
Hello Tom,
I'm not able to connect my AVG VPN, getting an error code: MRGK3M.
